SWEET! Shallow Water Equation Environment for Tests, Awesome!
What is SWEET?
This software allows a fast exploration / investigation / prototyping of time discretization methods for PDEs which can be solved with global spectral methods (Fourier & Spherical harmonics).
It’s made to
- accelerate research around the development of numerical time integration methods
- investigate new ways to express parallelization
- do some early investigations in scalability of novel time integration methods (e.g., parallel-in-time)
Check-out the list tutorials for some usage examples …
What is SWEET NOT?
SWEET is not intended to be any production HPC code to replace any dynamical cores (yet ).
Example
Features
Domains
SWEET supports periodic boundary conditions for
- the bi-periodic plane (2D torus)
- the sphere
Space discretization
- PLANE: Spectral methods based on Fourier space
- PLANE: Finite differences (with convolution in spectral space)
- SPHERE: Spherical Harmonics
Time discretization
- Explicit RK
- Implicit RK
- Leapfrog
- Crank-Nicolson
- Semi-Lagrangian
- Parallel-in-time
- Parareal
- PFASST
- Rational approximation of exponential integrators (REXI)
- T-REXI (Terry’s method)
- CI-REXI (Cauchy Contour integral method)
- B-REXI
- Spectral Deferred Corrections
- …and many more time steppers…
Special features
- Graphical user interface
- Fast Helmholtz solver in spectral space
- Easy-to-code in C++
Applications and benchmarks
There’s support for various applications
- Shallow-water equations on plane/sphere
- Advection
- Burgers’
